Air Handler On The Loose - HVAC - DIY Chatroom Home Improvement Forum
Old 08-28-2014, 09:51 PM   #1
Rewards Points: 12
Air handler on the loose
Hi. I have a Trane XL1800 heat pump with a TWE065E13FBO air handler; Trane Baystat 038A thermostat. Recently, the fan on the air handler seems to run all night. When I get up in the AM, it is still running. I can turn the entire cooling unit off, but the fan continues. If I turn the fan switch on, then off again, the fan goes off. Is this a relay problem? I have had it to do this months ago, but havenít noticed again until recently. The handler works fine during the rest of the day. Thanks for any input.
DrumMD is offline   Reply With Quote
Old 08-28-2014, 10:29 PM   #2
Rewards Points: 197
If it were me the first thing I would think of sitting in my lazyboy and where Id start....Hmmm Im going to have to get in that darn attic, kill the power, open the control panel and see if there is anything obviously looks burned on the board. If not blow the blanket of dust off the board with canned air, close everything up and pull out the original thermostat I have in storage that I know is working and switch out the thermostat to see if all is well.
CWO4GUNNER is offline   Reply With Quote
Old 08-29-2014, 05:48 AM   #3
An old Tradesmen
Rewards Points: 6,928
If its a programmable thermostat. Make sure the fan isn't set to on in the programming.
Old 09-16-2014, 02:30 PM   #4
Rewards Points: 12
Thanks; don't think it is the thermostat as it seems to work just fine with ups & downs all day---only sticks in the cool night time.
Old 09-16-2014, 02:36 PM   #5
PoleCat's Avatar
Rewards Points: 1,646
A sticking relay would usually not care if it were night or day or what ambient temperature is. This could be a good place to begin your trouble shooting though.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-16-2014, 04:05 PM   #6
An old Tradesmen
Check the thermostat programming if its a programmable one. It cost you nothing to check it.
Old 11-01-2014, 01:35 PM   #7
Rewards Points: 12
I have looked and looked to find the proper relay for this unit. Where can I find it? (I also had my HVAC man--saw him by accident--who said to change the relay)
Old 11-01-2014, 03:54 PM   #8
An old Tradesmen
I get them from Trane.
Air Handler Won't Stop Running, Help Please!!! Ralph III HVAC 31 06-02-2016 05:02 PM
Do I really need the air handler filter? Flt_Simulation HVAC 2 09-17-2012 10:38 AM
Return Vents and Air Handler Question hifiman HVAC 7 04-27-2012 06:44 AM
Air handler blower will not come on? davvid20120 HVAC 8 04-01-2012 12:55 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
