Old 08-31-2007, 09:28 PM   #1
Default Air Handler leaking when cycle ends
I installed an upflow air handler in a downflow configuration, as the HVAC retailer I bought it from said it would work. I flipped the coil over during the installation. The water appears to come off the coils during the cycle. When the cycle ends, water drains from the bottom of the air handler. I tried reducing the speed of the fan motor, which helped but did not eliminate the water coming out at the end of the cycle. I've seen air handlers that could be installed as upflow or downflow. Are the coils on those units different? How do I eliminate the water?
mannaserv is offline   Reply With Quote
Old 09-04-2007, 11:02 AM   #2
You probably should not have flipped the coil over unless the install instructions said to do so. The air can flow either way, but the water will always try to go downhill to the drain pan. Air going backwards through the coil will affect performance noticeably if it is more than two rows thick, in which case there will be some sort of means to address the drain issue - either a separately purchased kit or moving a pan or baffle that was shipped with or installed in the unit. The install instructions should have the details.
rogersor is offline   Reply With Quote
More On This Topic
Hi my name is Mark Delgado with American Auto Service for expert Village. Once in the evaporator coil it will obsorb the heat from the interior of the vehicle. Because the evaporator coil is deep inside the dash I just want to show an example of what it... Read More »
On behalf of expertvillage.com, my name is Angie Yarid from LA Wax and Skincare Center in good old sunny Miami, Florida and today we’ll be talking about the bioenergizer foot spa detox. Let’s take a look at what’s happening with Mary... Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
For the downhill use, you want more sag than that. More than twenty or thirty percent. You could use up to forty percent sag, and, it's the same sort of thing. I'll push down my little zip tie that I use to see how much travel I'm using. I'm going to get... Read More »
ball valve leaking bwall Plumbing 9 06-30-2009 10:37 PM
leaking bathtub mikeynholly Plumbing 1 02-11-2007 03:50 PM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 10:14 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 10:23 AM
Drainage from air handler jack B HVAC 1 05-07-2006 10:35 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
