Air Handler Leaking - HVAC - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 08:04 AM   #1
Air handler leaking
My air handler has been leaking water for some time now. The air handler is Allstyle SL model installed horizontally in the attic with the fan pulling air over the coils. The condensate line is clear. I can pour a pitcher of water down in the drip pan and it flows down the line quickly. But water continues to collect inside the air handler and drip out the seams into the emergency pan. If you feel underneath the air handler it is the most cold directly under the fan. I don't know if that means water is coming off the coils or if all air handlers are cooler underneath the fan. An AC tech decreased the fan speed but that didn't help at all. The second AC tech propped up the air handler to make sure it was level, but that also didn't help. I also had a p-trap put in with a vent after the p-trap but still no difference. Any ideas what is wrong?
kcamnairb is offline   Reply With Quote
Old 08-17-2011, 08:29 AM   #2
fabrk8r
fabrk8r's Avatar
Possible cracked primary drain pan. How old is the unit?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-17-2011, 02:14 PM   #3
Less than five years.
Old 08-17-2011, 02:30 PM   #4
Rewards Points: 338
are you monitoring the primary drain pan, the one inside the air handler? did you pour water in the secondary and visible pan underneath the air handler, or in the primary pan inside the air handler?
NitroNate is offline   Reply With Quote
Old 08-17-2011, 04:32 PM   #5
I opened the air handler and poured water into the drip tray that leads to the primary pan inside the air handler.
air handler leaking heat? denemante HVAC 1 12-01-2010 03:16 PM
Trane air handler leaking a ton of water organick HVAC 5 08-12-2010 07:29 AM
I need help with leaking air handler mdm HVAC 2 08-01-2009 09:10 PM
Air Handler leaking when cycle ends mannaserv HVAC 1 09-04-2007 09:02 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
