Hoping someone out there can help w/ this issue.
I'm running a heat pump for my top floors of my townhouse, and been having issues with it for a while now. I had a valve and the compressor replaced last year to fix a leak. It was working fine for a while, until I turned the A/C recently.
The airflow on the handler does not seem that high. I get more flow from vents closer to the handler, but less in the farthest vent. I closed off as many vents as possible, and it does help, but not as much. The incoming refrigerant pipe also freezes. I looked inside the handler, and the pipes are frozen there too.
Air coming out of the vents is cold, and I believe it may reach the 20deg difference.
My filters in both my supply vents are clean.
Anything else I can check? I dont have the model number of the handler on me, but can provide it tonight.
