Air Handler Fan Will Not Run Sometimes - HVAC - DIY Chatroom Home Improvement Forum
Old 06-06-2011, 05:23 PM   #1
Air handler fan will not run sometimes
I live in Texas and the AC blower inside has not started running 2 or 3 times over the past few months. The 1st time was while using the heat, and the last 2 times with the AC. I simply turn the unit off via the thermostat for say 15 minutes and then back on... and the inside air blower will start blowing again. I haven't gone into the attic as yet but I can hear the unit up there making some noise.
About 2 years ago, I replaced a starter capacitor on the compressor unit outside... now I'm wondering if that might be the same problem for the squirrel cage fan motor in the attic air handler. Should I just go buy a start capacitor for the air handler and replace that? Sounds like the logical thing to try but am looking for some more experienced advice.
phacops is offline   Reply With Quote
UV Lamp for Crawlspace Air Handler Earnie HVAC 10 01-03-2011 06:35 AM
SPace Pak Air Handler Wiring Question--208-230/60/1 metal121 HVAC 5 05-07-2009 05:52 AM
Space Pac Air Handler Wiring--208-230/60/1 Volts metal121 Electrical 4 05-05-2009 10:20 AM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 09:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
