Old 11-06-2008, 02:29 PM   #1
air handler fan/thermostat problem
Hi,
I have a ritetemp 8010 thermostat contented to a heat pump w/ aux heat.
Here is my problem: When I set the temp at 70 the fan and heat pump come on. When the temp hits 70, the heat pump goes off but the fan keeps running (on auto). If I manually move the set temp down, the fan will go off. Wiring problem?
Rickl is offline   Reply With Quote
Old 11-06-2008, 03:04 PM   #2
Sounds like a problem with the thermostat. Maybe its time for a programmable model.
dac122 is offline   Reply With Quote
Old 11-06-2008, 03:07 PM   #3
The Stat is only 3 years old. It seems to be wired correctly
Old 11-06-2008, 06:07 PM   #4
An old Tradesmen
How long has it been doing this?
Old 11-08-2008, 12:37 AM   #5
Uhh....three years.
LOL
Black Adder is offline   Reply With Quote
Old 11-11-2008, 05:03 PM   #6
Originally Posted by Black Adder View Post
Uhh....three years.
LOL
The green wire connected to your thermostat controls the fan operation. Most likely you have a faulty thermostat. Replace and see if this correct the problem.
pbservano is offline   Reply With Quote
Old 11-11-2008, 05:23 PM   #7
when heat satisfies check to see if you have power at the g term in the air handler if so the tstat is causing it also make sure tstat is wired correctly make sure somebody didnt jumper y to g or some crazy **** like that
kennzz05 is offline   Reply With Quote
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Phone Jack Hookup Problem kennykenny Electrical 18 12-07-2007 04:48 PM
Question about air handler blower problem whlnut HVAC 2 08-27-2007 02:01 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
