Air Handler Fan Sound - HVAC - DIY Chatroom Home Improvement Forum
Old 08-09-2015, 08:34 PM   #1
Rewards Points: 166
Air handler fan sound
My HVAC system is installed in a utility room on the second floor. When I stand right in the room beside the system, the blower fan sounds completely normal. However, when I am in a 1st floor room directly below the system, the fan sound has a definite rhythmic whine sound. Like earnnnn, earnnnn, earnnnn, earnnnn, continuously. Ocassionally I hear the sound go back to normal and then the fan shuts off shortly after. I have my thermostat set to add some XX seconds to keep the fan running after the heat/cool cuts off. I suspect that the sound change is when the fan speed changes after the heat/cool shuts down. Any one have an idea what may be going on here?
thanks
partner is offline   Reply With Quote
Old 08-09-2015, 09:29 PM   #2
Rewards Points: 3,892
Might be a harmonic vibration traveling through the lineset as the compressor runs.
roughneck is online now   Reply With Quote
The Following User Says Thank You to roughneck For This Useful Post:
zappa (08-10-2015)
Old 08-10-2015, 09:30 PM   #3
Rewards Points: 166
Is that even possible? The sticker on the unit says 60 ft. but I think its between 40-50 ft. I was thinking more of a light fixture in the ceiling maybe.
Old 08-10-2015, 10:00 PM   #4
Yes, it's a fairly common issue with linesets rubbing wall framing and/or equipment not operating properly.
supers05 (08-11-2015)
Air Handler Won't Stop Running, Help Please!!! Ralph III HVAC 31 06-02-2016 05:02 PM
Air handler blower will not come on? davvid20120 HVAC 8 04-01-2012 12:55 PM
Air handler leaking kcamnairb HVAC 4 08-17-2011 04:32 PM
Anoying sound in house water pipes when sprinklers are ON gante Plumbing 1 06-07-2010 06:04 AM
Sound dampening advice needed steel1 General DIY Discussions 10 10-22-2008 01:51 AM
