Air Handler Emergency Drain Pan Outlet - HVAC - DIY Chatroom Home Improvement Forum
Old 10-26-2007, 01:50 AM   #1
Rewards Points: 1,088
When is this outlet ever drained into the gutter? My experience is that this emergency pipe should be routed through the soffit and located in front of a window where if you see it dripping, that means your main condensation pipe is clogged.
If it's routed into your gutter, how will you ever know? Does this violate code?
handy man88 is offline   Reply With Quote
Old 10-26-2007, 07:22 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi handy man88
This is not against code. It is however a waste of pipe. You are corect in the fact that it should be placed in a conspicuous place so that it can be monitored. If you have the ability to do so, reroute it so it can alert you too a problem.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
