-   -   Air Handler Emergency Drain Pan Outlet (http://www.diychatroom.com/f17/air-handler-emergency-drain-pan-outlet-12718/)
handy man88 10-26-2007 01:50 AM
When is this outlet ever drained into the gutter? My experience is that this emergency pipe should be routed through the soffit and located in front of a window where if you see it dripping, that means your main condensation pipe is clogged.
If it's routed into your gutter, how will you ever know? Does this violate code?
#CARRIERMAN 10-26-2007 07:22 PM
Hi handy man88
This is not against code. It is however a waste of pipe. You are corect in the fact that it should be placed in a conspicuous place so that it can be monitored. If you have the ability to do so, reroute it so it can alert you too a problem.
Good luck
Rusty
