Air Handler ECM Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 09:39 PM   #1
GPR
I have a Carrier Air Handler (the inside unit). The blower motor will not start. It does not seem to rock back and forth. It spins freely by hand. A tech came out with a tester and ohm meter and pronounced the motor as bad. He wanted half my monthly income to replace it.
This is a two part motor. The actual motor and the module which is contained in the bottom of the motor.
I have taken them apart. I see no signs of damage or burning on the module. The motor ohms between each of the 3 input wires are all 11 ohms and to the case are open. I think this should mean the motor is good.
Everything that I read online seems to say that it is almost always the module that is bad.
I can get the complete unit (motor and module) for a third of the price I was quoted although I may have to buy a puller to get the motor off the fan. The module by itself is about 1/10 the price I was quoted. Some people have said that the module must specifically match my air handler. I am a bit confused as to why since it is the part number that goes with my unit.
So my dilemma is do I go with the cheapest and easiest possible solution or the more expensive but difficult to do solution.
Anyone have any ideals?
GPR is offline   Reply With Quote
Old 03-29-2013, 06:11 AM   #2
Rewards Points: 196
Sounds like you need a module as yes is needs to be the exact replacement for that unit.Either order by the model and ser # off unit or by numbers on the module it self .Carrier is allways updating part numbers so you need current replacement #.Probably a RMOD****** .
HVACTECH96 is offline   Reply With Quote
Old 03-29-2013, 12:27 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
yep, motor is good with those readings. The correct way to test for operation is with a techmate to determine if it is the module or control board.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-29-2013, 12:39 PM   #4
how
Rewards Points: 1,104
Take another real close look at the thermister on the module. It usually looks like a nickle or quarter that's encapsulated in black plastic and soldered to the module. Is it split or swollen? If so, then replacing the thermister might be a worthwhile try.
how is offline   Reply With Quote
Blower motor: Emerson to GE threeonesix HVAC 12 08-25-2011 03:59 PM
Wiring a replacement blower motor bodtchboy HVAC 17 08-11-2011 10:05 PM
Lennox Air handler motor keeps running diystarter HVAC 3 01-05-2011 04:04 PM
Air handler Blower Motor 205HVAC HVAC 2 05-24-2010 06:34 AM
Replace Condenser Fan Motor cnavazio HVAC 14 06-24-2009 09:57 PM
