Air Handler Condensation Drain - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2008, 10:41 AM   #1
Air Handler Condensation drain
Can you drain an air handler AC condensation pipe right into the ground?
We live in an old brownstone and the handler is downstairs. The floor is built 20 inches off the ground (dirt)
I was hoping just to drain this into a small hole and let it go into the ground water.
thoughts?
Rickl is offline   Reply With Quote
Old 11-11-2008, 11:12 PM   #2
yup its done all the time if you are the homeowner im sure its legal for you to do although it may not be code legal although most citys dont want you dumping unmetered sewage (free sewage) so its all good make sure you put a trap inline or you will probably have draining problems because of the negitive pressure exsisting in the drainline due to coil placement
kennzz05 is offline   Reply With Quote
Old 11-12-2008, 09:58 AM   #3
RippySkippy's Avatar
It would seem that if you dump condensate on the dirt, in the unconditioned space, it's going to be quite damp and could cause issues with anything wood in the area. Are there any another options? Could you dump it into a sump pit and pump it outside? Bury a sump pit in the dirt with holes in the bottom and a lid, letting the natural soil percolation remove the water from the sump pit.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 11-12-2008, 10:27 AM   #4
If you have a pump why not just run it outside and be done with it?
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Air Handler Emergency Drain Pan Outlet handy man88 HVAC 1 10-26-2007 07:22 PM
A/C Condensation Drain Sammy HVAC 6 05-13-2007 06:40 PM
