Old 04-10-2012, 02:33 PM   #1
Question
Air handler condensate-----> HELP
For years and years I've battled the condensate line coming from the air handler in my attic.
There is only room for about 1" of fall over 18' for the condensate line. This year I was trying to devise a way to raise the air handler further off the ceiling joists so I could get more fall. But it doesn't look like I can budge the air handler without a hoist or pulleys and there is only 20" inches between the top of the air handler and the attic roof.
I've heard about people using condensate pumps to help with gravity fed condensate discharge issues.
How effective are these? Should I try to find a way to get the PVC gravity discharge to work or will a condensate pump take care of this?
Thank you.
testerdiyc is offline   Reply With Quote
Old 04-10-2012, 03:17 PM   #2
Ive been installing hvac equiptment for 4 years now and have seen condesate pumps outlast the equiptment itself. If you do decide to get one go with a Little Giant Condesate Pump. They are avaliable in shallow or deep resvoirs depending on the application. Althought you'll have to buy the 1/2 inch clear tubing for the pump discharge. Hope it helps.
Hero40sn9s is offline   Reply With Quote
The Following User Says Thank You to Hero40sn9s For This Useful Post:
ben's plumbing (04-10-2012)
Old 04-10-2012, 03:36 PM   #3
Thanks for the vote of confidence.
Does anyone have a good resource to learn more about condensate pumps. I've looked into the Little Giant models but I am having a tough time deciding which one to buy.
I can't even figure out what is meant by "head pressure."
Hero40sn9s, do you happen to know if the clear tubing will weaken, over time, in at attic that goes from -20 Fahrenheit to 120 Fahrenheit each year? The clear tubing that I'm thinking of would probably collapse upon itself on a 100 degree day. My attic is unconditioned air.
Old 04-10-2012, 04:13 PM   #4
they are taling about hi high the punp will pump... I have used all types with no troubles..they are almost all bullet proof....
carmon is offline   Reply With Quote
Old 04-11-2012, 04:09 PM   #5
Since I have a condensate trap in my current gravity pvc drain line, will i still need a condensate trap when using a pump?
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 12:46 PM
Air handler blower will not come on? davvid20120 HVAC 8 04-01-2012 01:55 PM
Air Handler Won't Stop Running, Help Please!!! Ralph III HVAC 28 03-31-2012 11:48 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
KNOWLEDGABLE condensate advice needed Nestor_Kelebay HVAC 5 11-23-2008 08:06 PM
