Air Handler Breaker Tripped 2X - HVAC - DIY Chatroom Home Improvement Forum
Old 04-03-2013, 05:21 PM   #1
Rewards Points: 1,062
air handler breaker tripped 2X
People,
Breaker tripped 2X. Also, seems the circuit is also feeding a 110v circuit to bedroom light fixture as it is out too. Im gona check out the light socket integrity (its old). But if I dont find anything there, what next? Open up the air handler box?
Thaks!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 04-03-2013, 06:47 PM   #2
An old Tradesmen
Rewards Points: 6,576
If its also feeding a 110 to a bedroom. After you find the cue of the short and fix it. Run a separate line to the 110, or air handler, as the air handler is suppose to be on its own circuit.
The Following User Says Thank You to beenthere For This Useful Post:
noquacks (04-04-2013)
Old 04-04-2013, 03:37 PM   #3
Good tip on the ac being on seperate circuit. I didnt know. Found the problem- it was a distorted base on a regular light bulb! Easy! Thanks, beenthere.
no electricity in one room only breaker not tripped jimncena Electrical 3 11-05-2012 11:04 PM
Lost all power and breaker not tripped avro1 Electrical 18 02-24-2011 08:57 PM
Tripped breaker installing new light switch? tylermac Electrical 3 02-05-2011 05:57 PM
Breaker tripped after power outage. What's up? Leah Frances Electrical 14 02-12-2009 07:56 PM
Breaker tripped and won"t reset princessme Electrical 8 01-19-2009 08:10 AM
