Tempstar Air Handler FXM4X4800A1 Installed 09/2010.Tempstar Heat Pump TXH548GKA100 Installed 09/2010A/C system controlled by Carrier Comfort Zone 4 Zone System installed in 1992.
When AC comes on the Air Handler Blower runs for about 20 seconds then stops for 3 seconds then runs for about 20 seconds. This happens the entire time the system is running.
I turned the thermostats Heat Switch Off & the Cool Switch Off and turned the fan Switch from AUTO to ON & the blower motor did the same thing, blower runs for about 20 seconds then stops for 3 seconds then runs for about 20 seconds.
NO burning or other smells coming from the AC unit.
I opened the air handler service panel and this unit has a ECM Motor.
The blower wheel (squirrel cage) spins freely and is quiet.
The evaporators metal housing has what appears to be rust on the side under each of the copper lines where it comes out of the evaporator and goes back in. Not sure if this is normal for a 24 month old unit?
The evaporator coils fins are clean.
Other than shutting off & turning back on problem the system runs fine & the house is cool.
All three filters have been replaced.
