Old 02-04-2007, 09:11 AM   #1
Air Handler to Base gasket/seal??
My Rheem air handler installation manual suggests a gasket for sealing air handler base to sheet metal combustable base. (AH will be installed in downdraft configuration).
What's the best way to make this "gasket". (ie clear silicone seal, furnace mastic, foam weatherstripping tape)
hennyh is offline   Reply With Quote
Old 02-04-2007, 09:11 PM   #2
Thoroughbred Mopar Man
Hi hennyh
We use a silicone called RD PRO, this is a high temp silicone with excellent adhering properties. It made by Red Devil and you should be able to get it at about any HVAC supply house.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 04:46 PM
remove/replace tile over mud base jfm617 Flooring 1 07-07-2007 07:38 AM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 09:29 AM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 09:14 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
