Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Old 09-24-2009, 04:06 PM   #1
Air Handler
Should you be able to shine a light through the slant coil in the air handler?
I have tried and no light shines through.
Does this mean my coil is clogged or needs cleaning?
Thanks.
gobob2 is offline   Reply With Quote
Old 09-25-2009, 04:55 AM   #2
An old Tradesmen
Rewards Points: 7,356
Some coils from day one, a light won't shine through.
So a light test doesn't really tell you much on some coils.
When in doubt. Clean the coil.
SPace Pak Air Handler Wiring Question--208-230/60/1 metal121 HVAC 5 05-07-2009 05:52 AM
Space Pac Air Handler Wiring--208-230/60/1 Volts metal121 Electrical 4 05-05-2009 10:20 AM
Air Handler flow problems dewalt HVAC 12 04-30-2009 07:59 AM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 09:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
