Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 02:33 PM   #1
air handler
needs some help concerning carrier air handler all my thermostat wires are disconnected and it still wont run any suggestions?thanks scottmcd my air handler is working now fuse was blown now my unit outside wont come on any suggestions on that?
jame253 is offline   Reply With Quote
Old 07-16-2012, 03:04 PM   #2
HVAC Contractor
Rewards Points: 316
If your tstat is disconnected then it certainly won't run
Are you sure 240v power is available? You can check this with a meter, but if you're not sure how to use it DON'T TRY TO DO THIS. You can hurt yourself badly (or worse).
Some of these units have circuit boards with 3 or 5 amp automotive-type fuses on the boards. You might look on that board to see if the fuse is blown. If it is, then TURN THE POWER OFF, replace the fuse, and start it back. If it immediately blows again you've got a short, and you'll need to trace down that short. If you're not sure how to do that, you might consider calling someone to do this for you.
scottmcd9999 is offline   Reply With Quote
The Following User Says Thank You to scottmcd9999 For This Useful Post:
jame253 (07-16-2012)
Old 07-16-2012, 03:07 PM   #3
biggles's Avatar
shut the breakers off and the servcie switch at the furnace....then go up to the stat..where are all the iwres disconnected????
Old 07-16-2012, 04:35 PM   #4
ac unit
scottmcd gave me some good info it worked now my ac uniy wont come on any suggestions as what to do?
Old 07-16-2012, 04:43 PM   #5
biggles's Avatar
do you get FAN/ON just at the stat reset the service switch on the furnace then reset stat to cool
Old 07-16-2012, 05:28 PM   #6
service switch
where would the service switch be on the furnace would that be th air handler or the ac unit outside
Old 07-16-2012, 05:45 PM   #7
MarginallyQualified
Rewards Points: 2,464
It isn't on the AHU.
The CONTROL wire runs from the AHU outside...
But the power wire will be run separately from the panel to the outside.
The "switch" is often a pull out thingy (technical term) in that gray box near the condensing unit
hth
Old 07-16-2012, 05:52 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
It would be on the furnace. or within sight of the furnace... Every appliance needs its own disconnect, so the air handler gets one, the AC unit gets one, and the furnace gets one.
Old 07-16-2012, 06:22 PM   #9
biggles's Avatar
you have the utility switch on the side of the furnace and then the red plated emergency switch at the top of the stairs going down the basement or just into the garage both those switches kill the furnace,and outside as said a fused disconnect
Old 07-16-2012, 06:47 PM   #10
An old Tradesmen
Rewards Points: 7,816
Merged your threads, since they are all about the same basic problem. Makes it easier for teh people trying to help you.
Air Handler Won't Stop Running, Help Please!!! Ralph III HVAC 31 06-02-2016 05:02 PM
Return Vents and Air Handler Question hifiman HVAC 7 04-27-2012 06:44 AM
Air handler blower will not come on? davvid20120 HVAC 8 04-01-2012 12:55 PM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 09:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
