Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 09:29 AM   #1
Air handler
My rheem air handler is not shutting off, the compressor does just fine. There was alot of water in the pan.
Model# is RBHK-25J11NFE.
Any sugesstions?
tonyp1 is offline   Reply With Quote
Old 06-05-2012, 12:03 PM   #2
Drain line clogged, but we need to see your drain pipe set up, one line or 2 lines ? Can you post a picture. (Blower does not stop, that's a different problem. just turn the unit off for now, you need to get rid the water first)
clocert is offline   Reply With Quote
Air Handler Won't Stop Running, Help Please!!! Ralph III HVAC 31 06-02-2016 05:02 PM
Return Vents and Air Handler Question hifiman HVAC 7 04-27-2012 06:44 AM
Air handler blower will not come on? davvid20120 HVAC 8 04-01-2012 12:55 PM
SPace Pak Air Handler Wiring Question--208-230/60/1 metal121 HVAC 5 05-07-2009 05:52 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
