Old 10-24-2011, 05:29 PM   #1
air handler
How long does it take to install an air handler?
newtech333 is offline   Reply With Quote
Old 10-24-2011, 06:04 PM   #2
newtech's Avatar
air handler
It could take an hr or a couple of yrs..
Need to give more info..
Also, you need to change your name
newtech is offline   Reply With Quote
The Following User Says Thank You to newtech For This Useful Post:
Doc Holliday (10-24-2011)
Old 10-24-2011, 07:18 PM   #3
An old Tradesmen
air handler
Yep, varies with the way an area its being installed in.
Old 10-24-2011, 09:16 PM   #4
HVAC Tech/ Browns Fan
air handler
If you never did it before maybe 8 hours then be back in 2 week with a recall found you did something wrong.
Tator1076 is offline   Reply With Quote
Old 10-24-2011, 09:48 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
air handler
Depends on what your abilities are, or what your definition of air handler is.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 10-24-2011, 10:43 PM   #6
I'm Your Huckleberry
air handler
Depends on how many people, if any, you have helping and whether or not they know what they're doing, where the unit is located, the fit to pevious return and plenum, drain pan and lines, electrical wiring, correct tools, dollies, etc., etc.
With myself and one helper to lift remove the old air handler and lift in a new one into an attic, fitting and sealing, brazing, wiring, sealing, vacuuming, charging, 4 -4.5 hours. I do all the work, helper is usually too inexperienced and just helps me lift.
Doc Holliday is offline   Reply With Quote
Old 10-24-2011, 11:43 PM   #7
gregzoll's Avatar
air handler
Depends on how many cases of beer it takes.
Old 10-25-2011, 07:17 AM   #8
air handler
Depends upon the brand. Some brands take an hour others take a day or two.
COLDIRON is offline   Reply With Quote
Air handler leaking kcamnairb HVAC 4 08-17-2011 05:32 PM
SPace Pak Air Handler Wiring Question--208-230/60/1 metal121 HVAC 5 05-07-2009 06:52 AM
Space Pac Air Handler Wiring--208-230/60/1 Volts metal121 Electrical 4 05-05-2009 11:20 AM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 10:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
