Old 01-28-2007, 10:15 AM   #1
air in fuel line
hi again i have a problem all of a sudden came home the other night it was to be the coldest night this year and my red light was on so i instinctively bled the air out of my fuel line at the pump(i have had a pump noise in a previous thread so i figured that i would ty this first as the noise had gone away (i had cleaned the screen in the pump) for most of the season then about 4-5 days ago i heard it once and did not pay much attention to it) well the unit fired and worked fine for two days.came home again the red light was on bled it again and worked fine till about 3am (got up to go potty) red light was on agin i bled and fine. i called a friend who is a boiler guy and he is coming over later but said that he has never heard of this before. hopefully someone out there has and maybe can give me some ideas. thanks again for any help you guys are great for spending you're free time to help others out.
bob
pingers7 is offline   Reply With Quote
Old 01-28-2007, 11:35 AM   #2
air in fuel line
well my friend stopped by of course he can't find anything wrong when it is running fine so we looked around and he said that i should have a one way valve coming off of my tank on th other side of my filter (there is no valve at all) as my lines go up to the ceiling and then back down to the pump. he feels this may be a big contributer to my problem and that the pump needs to work harder to get fuel. sounds reasonable so i will get a valve and put one in. still if there are any other ideas i will check those out to. bob
Old 01-28-2007, 07:41 PM   #3
Thoroughbred Mopar Man
air in fuel line
Hi pingers7
There is a chance that the drive coupling on the burn pump could be bad. I am not real familiar with the light oil furnaces, but that is the most common cause of heavy oil or waste oil heater pump noises. The other could be your oil pressure regulator is going bad.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
3/4" gas line needs to be bigger raymond_anthony HVAC 11 10-28-2009 06:59 PM
ac suction line placement? nimbenja HVAC 8 10-28-2009 06:43 AM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
