Air Flow Test - HVAC - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 03:32 AM   #1
JJboy's Avatar
Air Flow test
Where I have to make the holes to do checking air flow?
For the Return between the filter and blower motor?
For the Supply between the blower motor and the EVAP coil?
Am I correct?
Thanks All, JJ
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 04-29-2011, 05:59 AM   #2
An old Tradesmen
Rewards Points: 6,118
On a furnace. Between the filter and blower motor, and between the furnace and evap coil.
On a standard air handler with the blower after the coil, between the filter and coil, and then in the supply plenum.
On an electric furnace with the evap added after the blower, between the filter and blower, and between the electric strips and the coil.
Old 04-29-2011, 03:25 PM   #3
JJboy's Avatar
I don't see this configuration.
Old 04-29-2011, 10:06 PM   #4
An old Tradesmen
Wanna borrow my glasses?
Guess its a good thing I didn't mention the other configuration, where you measure between the first coil and filter, and after the second coil.
Old 04-29-2011, 10:31 PM   #5
JJboy's Avatar
LOL, I'll try to figure it out.
Second Floor Vent Has No Air Flow somewhatsketchy HVAC 7 08-16-2010 01:32 PM
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 06:05 AM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 01:59 PM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-16-2009 12:09 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
