Air Flow - HVAC - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 04:17 PM   #1
Air flow
Can u use a 10 inch round flex pipe 25 feet long with 1 6 inch round flex vents branching off at every 6 feet for a total of four vents if so what should I use it's a 3 ton self contained unit heat pump using a 20 x 10 main trunk with 5 6 inch rounds running of that for the down stairs much needed help
tootsie007 is offline   Reply With Quote
Old 04-04-2011, 04:41 PM   #2
An old Tradesmen
Rewards Points: 6,510
The 20X10 if thats inside dimensions is border line for a 3 ton(actually, a bit small).
The 10" flex will carry 280 to 320 CFM quietly. Which is about what you would expect for 4-6" flex supplies.
Second Floor Vent Has No Air Flow somewhatsketchy HVAC 7 08-16-2010 01:32 PM
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 06:05 AM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-16-2009 12:09 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
Flow not Pressure problem??? DonM Plumbing 5 11-29-2007 06:53 PM
