Air Filters - One Dirty, One Clean - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 01:45 PM   #1
Question
Hello all,
I just changed the filters in my A/C units (last change was 3 months ago) and found that one was dirty and the other was clean. Both units were installed in the attic at the same time. The unit with the clean filter services the downstairs of our house, and the unit with the dirty filter services the upstairs. Here is what they looked like side-by-side.
Why would one filter be filthy while the other is still clean?
Thanks!
Neal_Texas is offline   Reply With Quote
Old 01-16-2012, 02:00 PM   #2
Rewards Points: 13,456
Down stairs have carpet and up stairs not?
Have the windows been open down stairs?
Any work on the house been going on down stairs?
My guess also would be that down stairs would be used more, cook in, outside door opening and closing more.
Any moisture or cooking grease will cause the filter to trap more dirt.
Old 01-16-2012, 02:54 PM   #3
Thanks for the reply. Actually, it's the opposite: the upstairs is the carpeted area because that's where the kids' rooms are, and the downstairs is all wood and tile. We don't have the windows open very often, but when we do we usually air out the entire house. That's part of what has me stumped!
Thanks!
Old 01-16-2012, 03:13 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Do your kids spend most of their time up or downstairs?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-16-2012, 03:14 PM   #5
Have the ducts cleaned in the whole house, the next filter change will be equal.
harleyrider is offline   Reply With Quote
Old 01-16-2012, 03:14 PM   #6
Are both filters located in the ceilings?
Thanks.
Old 01-16-2012, 03:19 PM   #7
Both filters are in the units in the attic. The kids play all over the house.
Old 01-16-2012, 03:25 PM   #8
So you do not run filters at the grills? You have return grills in the ceilings with ducts that lead to the return side of the furnace and the filter is there, in the unit? Can you take some pics?
Thanks.
Old 01-16-2012, 03:36 PM   #9
biggles's Avatar
one thing for sure the fan upstairs is running more then the downstairs...both returns are ducted to the back of each system in that attic?..your wife keeps the downstairs cleaner then the upstairs...
Old 01-16-2012, 05:21 PM   #10
Originally Posted by Neal_Texas View Post
Hello all,
Thanks!
First of all that is not dirt in the filter. It is fuzz and lint from carpet and
clothing. So you have that more up stairs then down.
The next factor is that the upper story picks up heat a lot faster, so the upper unit will run 3 tomes more than the lower story. Usually when you cool the upper story, the lower does not need that much cooling so it won't come on much. Paul
paul52446m is offline   Reply With Quote
Tags
filter , hvac
how to clean outside sump? BlueBSH Plumbing 4 01-27-2011 04:53 PM
Bottom drainage from brand new water heater is dirty... HVAC_NW Plumbing 3 11-02-2010 03:23 PM
How to clean porcelan tiles? Talking Dreams Tiling, ceramics, marble 4 02-08-2009 09:01 AM
Is there such a thing as a dirty heat exchanger? suthrnreject HVAC 8 01-19-2009 08:23 PM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 07:42 AM
