Old 09-19-2012, 11:59 PM   #1
Air Filter
Is there such thing as a 5 ton hypoallergenic central air filter?
Guvin is offline   Reply With Quote
Old 09-20-2012, 10:13 AM   #2
Air Filter
yes there is.
via google, read up on Merv ratings for air filters. The merv rating will help you find out how small a partical you want to filter. After that read up on filter air flow restrictions. after that search for 4 to 5 inch thick air filters. I dont know what type of filter holder you have, so you will have to figure out what works.
good luck... but remember restrictive air filters can kill your indoor blower motor and maybe even make the compressor unhappy.
bobinphx is offline   Reply With Quote
Old 09-22-2012, 09:18 AM   #3
An old Tradesmen
Air Filter
Probably gonna be better off using a MERV 13 media air filter, and then add a HEPA filter system. Most 5 ton units don't get enough air so as it is, let alone when trying to use anything higher then a MERV 13..
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
Inground pool and filter...HELP! Blpavlovich Building & Construction 2 06-09-2011 06:49 PM
furnace filter fit?? Doug7852 HVAC 4 04-01-2011 11:45 AM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 10:12 AM
