Air Exchanger. Replace Room Switches With Timers? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 07:48 PM   #16
Thumbs up
Originally Posted by beenthere View Post
Regular single pole switches used for lights. Are dry contact switches.
The spring wind timer switches at HD, are also dry contact.
Now the question remains if the switching contact/s on the control board are dry contacts (a/o powered switching), too. But even if the control board switching terminals are not dry contact type, it'll still work. Only the voltage and amp. rating (of the switches) must be compatible.!
spark plug is offline   Reply With Quote
Old 05-12-2010, 07:51 PM   #17
An old Tradesmen
Rewards Points: 8,164
The terminals that you connect a switch to. Can't be dry contacts.
if they were. then nothing would work. Since there would be no power/electric for the switch to control.
Old 05-12-2010, 08:16 PM   #18
Thumbs up
I withdraw that statement on a/c control. But in intercom systems manufactured by Aiphone (this is not meant as an endorsement. Just for useful information purposes. M.K.) where you can control an independently powered entry door buzzer system from the IC unit. those terminals are Dry Contact. Yes. I see the distinction. Thank You.!
Room Air Purifier - which is best? nhart Appliances 17 07-29-2014 09:00 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 02:51 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 05:34 PM
Room to Room Vent cjpilot HVAC 5 12-02-2007 08:53 PM
