Air Exchanger.. - HVAC - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 09:41 PM   #1
air exchanger..
i have a 1300 square foot home . i have radaint floor heat i need a air exchanger as the house is way to tight... with radaint floor heat would you really need one that heats the air as it comes in .. my kids open the door and when the close it there is no real temp change in the house due to the heat coming from floor. and suggestions ...
chessy is offline   Reply With Quote
Old 07-16-2012, 10:33 PM   #2
Missouri Bound's Avatar
They work by letting the fresh air mix with the existing room air. Not really heated except by the proximity of the ductwork. And it's a great idea.
Do you want it your way or the right way?
Old 07-17-2012, 06:08 PM   #3
Rewards Points: 266
You get a heat exchanger (heat recovery ventilator, HRV) that warms or cools the air with the air going in the opposite direction. If you want to keep the humidity where it is as well, you need and ERV, energy recovery ventilator.
ionized is offline   Reply With Quote
Air Exchanger and A/C fan Seriak HVAC 8 04-27-2012 12:46 AM
Flame Rollout - Bad exchanger or cracked inducer housing gl35 HVAC 4 03-05-2011 12:02 PM
Rheem Heat Exchanger Noise Vulcanus HVAC 0 12-19-2010 10:42 PM
Is there such a thing as a dirty heat exchanger? suthrnreject HVAC 8 01-19-2009 08:23 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 03:57 PM
