Old 04-19-2010, 09:24 PM   #1
Air duck life span / Air flow
I recently purchused a forclosed home and have come to find that some of the duct work in the crawl space is in disrepair. The house was built in 1974 (not sure if it is original duct or not) What is the life span of crawl space duct work. Also, a previous owned bricked up the garage and built a subfloor and did run duck work into the room under the subfloor but the air flow is low in that room. Is that because they didnt replace the HVAC unit or because the duct is to small? I have a funny feeling that im going to have to replace th unit and all the duct work, does this happen alot?
ACE II is offline   Reply With Quote
Old 04-19-2010, 09:48 PM   #2
What kind of duct? Flex can tear but is easy to fix or replace. Tin duct will last forever if it's not wet. No idea on duct board,nobody in the area uses it.
Not enough air in the addition could be too small of duct or the placement of the branch. Good air flow in the rest of the house?
Old 04-19-2010, 11:03 PM   #3
An old Tradesmen
For the renovated garage. Cap off the supplies it has now. And install a mini split. Much cheaper then a whole new system and duct work.
Old 04-20-2010, 08:05 AM   #4
addition has flex but it sags and seems bad inside.. not sure why. the rest is metal. Has anyone ever had there ducts cleaned out?
flex duck vs metal duck fhammette HVAC 21 12-19-2011 07:30 AM
What is the average life span of a sump pump? Fred311 Plumbing 8 01-27-2010 09:41 PM
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 1 10-09-2009 01:24 PM
Whats the life span of a cricket?? 4just1don Pest Control 1 01-09-2009 07:44 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
