Air Deflector Won't Fit Ductwork... - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 10:02 AM   #1
Air Deflector won't fit ductwork...
I am having a problem where the standard 9.5" duct air deflectors do not fit my 9.25" ductwork. My house was built in the late 50's and has the square metal ducts. Is there any better solution besides trimming back the ductwork and taping it to the wall so that a new deflector can fit? I can't seem to find any deflectors that will fit this size duct.
Please let me know if pictures would be helpful. I am at work now, but I can snap a few later today.
Thanks,
Nate
natedro is offline   Reply With Quote
Old 09-06-2011, 03:06 PM   #2
REP
Yes do need pictures.Your discription is too vague for us to reply.
REP is offline   Reply With Quote
Old 09-06-2011, 07:13 PM   #3
ok will post momentarily. Thanks for your reply.
Old 09-07-2011, 08:17 PM   #4
So the inside width of the duct is 9.25". The ducts you buy at HD/Lowes are all 9.5" inside (for the louver parts that go about an inch in). What are my options here? Should I cut the duct back an inch or so and then just tape the duct to the wall? ...or is there a better (less rigged) option I can't seem to think of?
Thanks,
Nate
Come by and visit our renovation 'blog': '59ish Brick Ranch: Updating... everything...
Old 09-11-2011, 10:00 AM   #5
Originally Posted by natedro
<img src="http://www.diychatroom.com/attachment.php?attachmentid=37844"/>
Thanks,
Nate
Bump. Anyone?
Old 09-11-2011, 10:20 AM   #6
I'm Your Huckleberry
Rewards Points: 2,270
There are hvac specialty stores which carry specialty parts/sizes for damper's or deflectors or whatever. Lowes and The Home Depot are generic at best. If you are no wanting to just rig this up than I'd try calling some hvac companies and finding out what duct supply houses are in your area and then call them.
Doc Holliday is offline   Reply With Quote
Old 09-11-2011, 10:22 AM   #7
That's exactly what I was hoping to hear. Thanks. I tend to order everything online and couldn't find that information online anywhere.
Old 09-11-2011, 10:30 AM   #8
http://www.lashleyinc.com/
Old 09-11-2011, 10:37 AM   #9
Custom Duct
8321 Hempstead Road, Houston, TX 77008-6131 (713) 868-5557 ()
Old 09-11-2011, 10:40 AM   #10
You can enter something such as "a/c duct supply house" in your google search engine for whichever city you are in and you should get a list.
I just hit on about 2 dozen for here.
Old 09-11-2011, 10:57 AM   #11
Originally Posted by Doc Holliday View Post
Custom Duct
This is a sheet metal duct supply house, they will build whatever you need to the exact measurements you give them.
The Following User Says Thank You to Doc Holliday For This Useful Post:
natedro (09-13-2011)
Old 09-11-2011, 06:58 PM   #12
Wow. Thanks. I appreciate the help!
Old 09-13-2011, 10:15 AM   #13
REP
You are only talking about 1/4 inch.That is 1/8 inch on either side.
You should be able to use a 2x4 and a hammer and tap out 1/8 inch on both sides.
Thats what I would try first.
Old 09-13-2011, 10:20 AM   #14
I suppose I could try that, but we are talking about ductwork that is likely 50 years old. It just doesn't seem like it would be able to take that without splitting or bending the wrong way to me. However, you're right and that's something easy (and free!) to try first.
Thanks.
Old 09-13-2011, 10:23 AM   #15
You can always make a 1" thick filler frame from wood with the 9 3/4" inside openning,than screw the grille to the new frame.may save a few bucks for you.
Marbledust is offline   Reply With Quote
Tags
air , deflector , duct , hvac
A/C and Ductwork Efficiency Jessidog HVAC 1 07-29-2011 07:48 PM
Ductwork Insulation tk3000 HVAC 3 11-19-2010 04:08 PM
plastic ductwork vs. metal: acoustic duct liners jjpclev HVAC 5 02-26-2010 07:29 PM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 03:11 PM
Tapping into basement ductwork BasementVirgin HVAC 7 09-10-2009 09:01 PM
