Old 06-27-2010, 07:21 PM   #1
Question
Air conditioning short
Our Carrier central air/furnace will not cool. I put the a/c to cool and after running for a couple of minutes it turns the furnace on while still set to cool. I've replaced the thermostat and still the problem persists. I don't know if it's a short on the system itself or some other electrical problem. The LED light blinks a 12 code meaning normal operation.
mike83291 is offline   Reply With Quote
Old 06-28-2010, 12:38 AM   #2
retired elect/hvac/plumb
plummen's Avatar
sounds like jacked up low voltage wiring or stat
plummen is offline   Reply With Quote
Old 06-28-2010, 10:30 AM   #3
I removed the W wire from the control panel on the unit. This stopped the inducer from turning on and the furnace from lighting. After doing this the a/c worked fine. But I have to assume that as soon as I reattach the wire to the control board the inducer will kick back on. Suggestions?
Old 06-28-2010, 05:54 PM   #4
Sounds like a short in the low voltage wire between the furnace and thermostat.
Tags
air conditioning, carrier, short, wiring
Vinyl sheet-cut too short for bathroom flooring tennisdoc1 Flooring 2 04-06-2010 08:30 PM
Short Wires in an Overfill HooKooDooKu Electrical 34 01-31-2010 01:18 AM
Short Circuit but Breaker does not trip vino82 Electrical 6 01-29-2010 01:54 PM
furnace and air conditioning package price MichaelV HVAC 3 12-02-2008 09:19 AM
Need Help Repairing Hair straightener (CHI-brand) Electrical Short. m_holder Electrical 2 09-12-2007 06:14 AM
