-   -   Air conditioning short (http://www.diychatroom.com/f17/air-conditioning-short-74800/)
mike83291 06-27-2010 06:21 PM
Our Carrier central air/furnace will not cool. I put the a/c to cool and after running for a couple of minutes it turns the furnace on while still set to cool. I've replaced the thermostat and still the problem persists. I don't know if it's a short on the system itself or some other electrical problem. The LED light blinks a 12 code meaning normal operation.
plummen 06-27-2010 11:38 PM
sounds like jacked up low voltage wiring or stat
mike83291 06-28-2010 09:30 AM
I removed the W wire from the control panel on the unit. This stopped the inducer from turning on and the furnace from lighting. After doing this the a/c worked fine. But I have to assume that as soon as I reattach the wire to the control board the inducer will kick back on. Suggestions?
Marty S. 06-28-2010 04:54 PM
Sounds like a short in the low voltage wire between the furnace and thermostat.
