Air Conditioning Coolant - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 09:52 PM   #1
Air conditioning coolant
How many pounds of Freon in a home air conditioner?
Skyeblue is offline   Reply With Quote
Old 08-23-2011, 10:20 PM   #2
JJboy's Avatar
Check the label on the condenser unit ( outdoor unit )
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-23-2011, 10:50 PM   #3
Rewards Points: 6,652
There is no freon inside the home in the air. There is Refrigerant used in many products for cooling & with some that also heat the air, by using the molecules in the outside air.
Old 08-24-2011, 07:18 AM   #4
Rewards Points: 1,214
Is the unit Central air or a window unit?
If it's a window unit probably Oz's, If it's a Central unit it's probably #s and Oz's.
Check name tag as mentioned
COLDIRON is online now   Reply With Quote
Old 08-24-2011, 09:47 AM   #5
Freon is the brand name of the refrigerant. But to answer your question, anywhere below 5 lbs.
HVAC-RMAN is offline   Reply With Quote
Old 08-24-2011, 03:22 PM   #6
Not true depending on the size of the unit and line set if it's central air.
Alot of people say freon like car how many models of cars are there?
Old 08-24-2011, 06:52 PM   #7
As stated it depends on the unit. Mine's a 2 year old high SEER 2 ton and it holds over 11 lbs of refrigerant.
Old 08-24-2011, 11:10 PM   #8
As I have stated before..Trane xl1400 5 ton holds 22lbs..
Master of Cold is offline   Reply With Quote
coolant indicater staying cooler than normal raptor99 Automotive Repairs 5 02-16-2010 04:19 AM
Oil FLUSH and Coolant FLUSH Question. LordX Automotive Repairs 14 08-20-2009 02:28 PM
2002 Saturn Vue Oil in the Coolant brokenhammer Automotive Repairs 3 06-29-2009 01:24 PM
furnace and air conditioning package price MichaelV HVAC 3 12-02-2008 09:19 AM
help, Poor performing AC, coolant leak? damaged coil? images maverick06 HVAC 5 07-31-2007 06:30 PM
