-   -   Air conditioning coolant (http://www.diychatroom.com/f17/air-conditioning-coolant-115058/)
Skyeblue 08-23-2011 08:52 PM
How many pounds of Freon in a home air conditioner?
JJboy 08-23-2011 09:20 PM
Check the label on the condenser unit ( outdoor unit )
gregzoll 08-23-2011 09:50 PM
There is no freon inside the home in the air. There is Refrigerant used in many products for cooling & with some that also heat the air, by using the molecules in the outside air.
COLDIRON 08-24-2011 06:18 AM
Is the unit Central air or a window unit?
If it's a window unit probably Oz's, If it's a Central unit it's probably #s and Oz's.
Check name tag as mentioned
HVAC-RMAN 08-24-2011 08:47 AM
Freon is the brand name of the refrigerant. But to answer your question, anywhere below 5 lbs.
COLDIRON 08-24-2011 02:22 PM
Not true depending on the size of the unit and line set if it's central air.
Alot of people say freon like car how many models of cars are there?
Marty S. 08-24-2011 05:52 PM
As stated it depends on the unit. Mine's a 2 year old high SEER 2 ton and it holds over 11 lbs of refrigerant.
Master of Cold 08-24-2011 10:10 PM
As I have stated before..Trane xl1400 5 ton holds 22lbs..
