Air-conditioning - HVAC - DIY Chatroom Home Improvement Forum
Old 08-21-2010, 07:05 AM   #1
Air-conditioning
I have two AC intakes on a wall , one toward the ceiling and one toward the floor. Technician said that I should close one toward the floor so that hotter ceiling air will be cooled. i've noticed that the rooms are warmer. Should I close the top one or just keep both open?
oldphil is offline   Reply With Quote
Old 08-21-2010, 09:59 AM   #2
Rewards Points: 6,652
You have what is called a Summer/Winter cold air return.
http://www.askmehelpdesk.com/heating...rn-127464.html
Old 08-21-2010, 11:56 AM   #3
An old Tradesmen
Rewards Points: 6,066
Leave both open.
Very doubtful that either is large enough by itself.
As a test. Open both. While the A/C is running. Put a tissue at the bottom one, and see if it holds the tissue against it. Then repeat with the top one. If it holds at both of them. Then you need both of them open.
Where are your supply registers. often, the correct registers can solve warm room problems, if the A/C and duct work is large enough.
Air conditioning short mike83291 HVAC 3 06-28-2010 05:54 PM
Air Conditioning Unit Bones1669 HVAC 1 07-19-2009 02:50 PM
furnace and air conditioning package price MichaelV HVAC 3 12-02-2008 09:19 AM
Microwave Fan Turns on Air Conditioning - help please Littledj HVAC 16 07-03-2008 09:23 AM
Bryant Air Conditioning Unit ARTLEE HVAC 1 07-01-2007 08:22 AM
