-   -   Air Conditioners as water coolers (http://www.diychatroom.com/f17/air-conditioners-water-coolers-143059/)
HTS 05-07-2012 08:40 PM
Is there a way to use and air conditioner to extract heat from a tank of water, say 50 gallons. The water tank will be approx. 80 - 90 F and my thought was to retrofit and AC unit to cool the tank to around 65 - 75 F. Is this possible OR just an impossible dream. Any help would be most appreciated.
biggles 05-07-2012 09:52 PM
a ground source heat pump setup will chill the water but what to do with all that heat at the other end.how long to bring the water down is a tonnage situation
Total Tool 05-07-2012 09:56 PM
I'm not really sure what you're trying to do, but they sell aquarium chillers that would cool your water down. They are usually used on large reef tanks where the high intensity lighting heats up the water.
hvactech126 05-07-2012 10:28 PM
Yes, you are basically talking about a chiller. You would need to cycle the water through a heat exchanger. I would be an expensive setup. Not sure what you are trying to do with the chilled water?
beenthere 05-08-2012 04:32 AM
They make smaller plate heat exchangers that will work for what you want. At 15 degree difference thats only around 6,000 BTUs that your looking to remove, so it won 't take a 1.5 ton condenser long to cool the 50 gallons down to the temp you want. About 20 minutes.
Code05 05-08-2012 04:39 AM
Gotta link?
beenthere 05-08-2012 04:44 AM
http://coolheatstore.com/brazed-plat...gn=google_base
Code05 05-08-2012 05:06 AM
Originally Posted by beenthere (Post 916970)
Thank you.:thumbsup:
