Air Conditioner Woes - HVAC - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 01:46 PM   #1
We had our furnace/air conditioner installed brand new in 2004 with it being maintained every year.
This year, the air conditioner is having a problem that I noticed when I first tried starting the unit.
The compressor seems to not engage. I've taken a video that will demonstrate what is going on.
Listen for the sounds at 8 seconds, 27 seconds and 53 seconds. Is this something serious, or something that I could fix? We're trying to be smart about this.
Unit RUUD Acheiver Model UAKA-024JAZ
junoinga is offline   Reply With Quote
Old 03-19-2011, 01:51 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 376
It is something SERIOUS. your compressor is not running and having a very hard time trying to start and is cutting out on it's internal overload. STOP using it that way or the compressor may burn out. May need a new dual capacitor and it also sounds like there may be damage inside it. I would get it checked by a Pro as the freon level needs checking when he gets it running. Also the outdoor coil needs cleaning and indoor coil needs checking etc.
Old 03-19-2011, 01:58 PM   #3
We haven't ran it. We turned it off right when it happened, It ran for no longer than 5 minutes. I will check the capacitor to see if thats the fix. The freon levels were recharged last year.
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 10:29 AM
Air Conditioner Wiring Cano Electrical 3 06-28-2010 07:18 AM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 06:07 PM
air conditioner tripping at current interrupter donny.frankrice HVAC 10 07-07-2009 02:08 PM
Hole in Cinder Block Wall for Small Air Conditioner stevehgraham Building & Construction 1 02-20-2009 06:31 AM
