Old 09-30-2012, 05:54 PM   #1
Air conditioner sleeves
I am looking for replacement sleeves for window a/c's installed in the walls of a condo complex. The sleeves are rusty, but the ac's are in good condition. Can anyone tell me where I can find sleves for these units.
Judy Wilson is offline   Reply With Quote
Old 09-30-2012, 06:46 PM   #2
biggles's Avatar
if there not rotting out they can be wire brushed primed up and color sprayed again. is it the outside or where they slde into..? ordering just the sleeves can get real expensive
Old 09-30-2012, 08:25 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Go find a sheet metal shop and give them the dimensions that you need, for the replacement sleeves.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 10-02-2012, 05:14 PM   #4
It's the outside sleeve that the a/c goes into. This problem is constent because the property is on the beach, and gets a lot of salt spray.
Old 10-03-2012, 07:38 AM   #5
Most sleeves I have seen are very difficult to replace and many times are built in the exterior wall when the building is being constructed and is very heavy gage steel very difficult to replace. I would recommend what others have said wire brush and paint. Or ask the Condo maintenance person what they recommend.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 10-03-2012, 07:50 AM   #6
Some research into the several Plastisol coating products available may be a solution for the harsh environment rather than replacement. If you are lucky there will be a shop with that service close by otherwise it may be a DIY job.
Fairview is offline   Reply With Quote
How I can repair My new air conditioner that drip water into my room? skolo HVAC 7 07-15-2011 12:12 PM
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 11:29 AM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 07:07 PM
Veranda composite post sleeves fit easily stansongman Carpentry 10 09-26-2009 02:31 PM
window unit air conditioner help? greenvorlon Appliances 1 08-03-2007 12:50 PM
