-   -   Air conditioner sleeves (http://www.diychatroom.com/f17/air-conditioner-sleeves-158484/)
Judy Wilson 09-30-2012 04:54 PM
I am looking for replacement sleeves for window a/c's installed in the walls of a condo complex. The sleeves are rusty, but the ac's are in good condition. Can anyone tell me where I can find sleves for these units.
biggles 09-30-2012 05:46 PM
if there not rotting out they can be wire brushed primed up and color sprayed again. is it the outside or where they slde into..? ordering just the sleeves can get real expensive
gregzoll 09-30-2012 07:25 PM
Go find a sheet metal shop and give them the dimensions that you need, for the replacement sleeves.
Judy Wilson 10-02-2012 04:14 PM
Air Conditioner Sleeeves
It's the outside sleeve that the a/c goes into. This problem is constent because the property is on the beach, and gets a lot of salt spray.
COLDIRON 10-03-2012 06:38 AM
Most sleeves I have seen are very difficult to replace and many times are built in the exterior wall when the building is being constructed and is very heavy gage steel very difficult to replace. I would recommend what others have said wire brush and paint. Or ask the Condo maintenance person what they recommend.
SeniorSitizen 10-03-2012 06:50 AM
Some research into the several Plastisol coating products available may be a solution for the harsh environment rather than replacement. If you are lucky there will be a shop with that service close by otherwise it may be a DIY job.
