Air Conditioner Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 11:56 AM   #1
Rewards Points: 194
First, let me start off with a "happy Father's Day," it seems our work is never done!
I came home yesterday to find my house hot. The air conditioner wasn't working and I had no clue what was wrong. The thermostat was working, the breakers were all OK, but the compressor was not working. Also, the compressor fan was turning very slow and intermittently.
Fast forward to this morning: I turned on the AC and got great cold air. However, when I went outside, I only heard the compressor but I didn't hear the fan. I shut it off quickly and I now think I have a capacitor problem. I think that it didn't work last night because the compressor fan quit, causing the compressor to overheat. It cooled down enough this morning to start working again...I just hope no permanent damage was done.
I'll be checking the capacitor after my Father's Day breakfast this morning. Is an AC capacitor a common part? Or am I looking at a special order with a week delay in getting it? My AC is an old (early 1980's) Rheem. Any advice would be appreciate, and I should have more information after I get the unit apart.
loftezy is offline   Reply With Quote
Old 06-17-2012, 12:01 PM   #2
Rewards Points: 2,516
You will be able to get a capacitor at any supply house. They are common. If the top of your cap is bulged then it is probably bad. Attached is a photo of a dual run capacitor. Notice the bulged top on the left photo and a normal working capaciotr at the right.
hammerlane is offline   Reply With Quote
Old 06-17-2012, 12:04 PM   #3
Tired & Dirty
Rewards Points: 83
The capacitor a common part, available at the parts house, or you can order them on line like Grainger etc. Really need to check it with a mulitmeter to be sure it is the cap and not the motor.
evapman is offline   Reply With Quote
Old 06-17-2012, 12:05 PM   #4
JJboy's Avatar
Capacitors are a common problem in A/C.....The compressor has a thermo switch internally to protect from overheating. You can get the capacitor on your local Grainger
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-17-2012, 03:48 PM   #5
Rewards Points: 194
OK, so I have two capacitors and I'm not sure which one should be the problem. Here is a picture of the big one that I took out and then the other one that's still installed. I tested the big one, and I'm getting roughly 20 microF between common and the other two terminals. Is that too high, or about right?
Should I pull the other one out and test it?
Old 06-17-2012, 03:54 PM   #6
JJboy's Avatar
Looks like the problem is the another one
Old 06-17-2012, 04:08 PM   #7
Rewards Points: 194
I think you might be right. I pulled the second one and I got a very low nanoF number (it didn't even register in the micro range).
I'll try to buy a 5mF 370 VAC capacitor tomorrow. Let's hope that the new capacitor will fix it!
Old 06-17-2012, 04:48 PM   #8
JJboy's Avatar
5mf 370VAC or 440VAC
Old 06-18-2012, 01:14 PM   #9
Rewards Points: 194
I replaced the smaller capacitor and my AC is fixed. Thanks for your help!
Old 06-22-2012, 12:55 AM   #10
I may be having the same problem: 1. AC started blowing air (not cold or hot) to upstairs rooms. Did a visual inspection of outside unit and I could hear a slight hum/buzz, but the fan was running. Wondering if I have electrical issues?
Hot air tonight, and tomorrow begins the weekend.
JJBoy are you in Austin area? SERVICE CALL POSSIBLE?
PM me or send to email mraygarcia at hotmail with contact info.
thanks,
Mray is offline   Reply With Quote
Old 06-22-2012, 03:39 AM   #11
McCumber12's Avatar
well
Thanks for your post.
McCumber12 is offline   Reply With Quote
Old 06-22-2012, 05:12 AM   #12
JJboy's Avatar
Yes, Im in Austin. Send me a msg.
Sent from my iPhone using DIY Forum
How I can repair My new air conditioner that drip water into my room? skolo HVAC 7 07-15-2011 11:12 AM
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 10:29 AM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 06:07 PM
Owen or Certain Teed has less problems?? reeses Roofing/Siding 10 02-07-2009 08:35 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
