Air Conditioner Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 12:46 PM   #1
Rewards Points: 160
Air conditioner not working
I swear I try to finish a project and another problem occurs.
I went ahead and uploaded my thermostat install I did myself. I want to make sure its installed correctly. The heat and central fan work with no problem, but when I test the A/C unit I get nothing.
When I test the A/C it doesn't make any buzzing sound or anything. Its only 6 years old. My guess is either I have a bad breaker at the fuse box location or maybe there is a bad fuse located in the A/C unit?
I didn't test the A/C when I installed the thermostat (dumb of me) so I guess it could be a faulty thermostat maybe?
Just hope there is an easy/cheap solution to this because my finance wants to call someone.
Its a ecobee smart si with 1 stage cooling and 1 stage heating.
word2yamutha is offline   Reply With Quote
Old 05-02-2013, 08:01 PM   #2
An old Tradesmen
Rewards Points: 8,172
Run a jumper from the RH terminal to the Y terminal. if the A/C comes on. Then it could be the thermostat.
Old 05-02-2013, 09:59 PM   #3
Rewards Points: 160
how do I set a jumper there?
Old 05-02-2013, 10:05 PM   #4
An old Tradesmen
Just use a piece of wire. Strip both ends and then touch them to those terminals.
Old 05-02-2013, 10:07 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
why do you have two wires in the C terminal in the stat? was that like that prior to your new stat install? I have a fleeting suspicion the condenser is not being told to come on due to the common wire from the furnace to the condenser being hooked up in the stat...??
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-03-2013, 12:33 AM   #6
Rewards Points: 160
No the other thermostat didn't have this kind of hook up. Here is the former thread regarding the thermostat installation Installing new thermostat
As you see in the ecobee si installation it says there is suppose to be 2 wires in the common terminal. http://www.ecobee.com/wp-content/the...l3_general.pdf
Old 05-03-2013, 04:26 AM   #7
An old Tradesmen
Don't see where it says there is suppose to be 2 wires in the common. Most set ups have the wires for the condenser at the furnace or air handler, not ran to the thermostat.
If you look at the wiring diagrams, it also does show that.
No harm in it though.
Lights and outlets stopped working (hot and ground crossed?) JordonBoss Electrical 2 03-13-2013 07:12 AM
Outdoor outlet not working - need advice amodoko Electrical 10 12-16-2012 12:42 PM
How I can repair My new air conditioner that drip water into my room? skolo HVAC 7 07-15-2011 11:12 AM
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 10:05 AM
Some things not working on a circuit while others are? speedster1 Electrical 7 11-24-2010 06:23 AM
