#1 |
Air conditioner not starting - Help needed.
Hello All,
A few days ago the AC in our home stopped turning on. The air handler / furnace is located in the attic directly above the thermostat. At the thermostat when we turn the switch to cool and lower the temperature, we hear slight "click" at the thermostat then a fan starts up in the attic. Usually, about 20-30 seconds after the fan starts up, another small click is heard (in attic) and the AC starts blowing cool air. What is happening now is we still hear the click at the thermostat, the fan will come on for about 40 seconds or so then everything shuts off. I checked outside and the unit on the side of the house is spinning when we turn the AC to cool. I went up in the attic and removed some access panels to view the control board. Behind this control board is what appears to a cylindrical metal shroud which a fan inside. This is the fan that spins upon switching the thermostat on. Next to the control board, I see an oval shaped starting capacitor, which a friend told me could be culprit. Is this capacitor used for starting the fan or the compressor? Where is the compressor? The unit is a York model P3Hu (about 13 years old). The control board is a white-rodgers 50A50-241. Any help or information you can provide is greatly appreciated. Thanks in advance, Phillip |
#2 |
This capacitor is for blower motor. On the thermostat try FAN on.....you should have blower motor running constantly. Let me know what happen
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead. |
#3 |
Hi! Thanks for the reply!
I set the thermostat to FAN ON and the blower motor ran for about a minute before shutting off. Also, when the FAN blower was on, it didn't seem to move any air at all through the vents. Does this motor have two speeds? Thanks, Phillip |
#4 |
model and serial number? post some images.
#5 |
Model #:P3HUC20L06401B
Serial # S)EDHM545249Images are attached. Thanks, Phillip |
#6 |
An old Tradesmen
P3Hu should be a furnace model number. Your compressor is in the condenser that is outside of your house somewhere.
#7 |
Sorry, I thought you wanted pictures of the unit in the attic.
Here is the model and serial of the outside unit. Model = H2RA060S06D Serial = ( S ) EFHM655192 |
#8 |
An old Tradesmen
Is the outdoor unit running even when the indoor stops running.
#9 |
You can start testing the capacitor
#10 |
#11 |
Yes, the outdoor unit (at least the fan on top of the condensor) continues to run after the blower in the attic shuts off.
How can I go about testing the cap? Thanks! |
#12 |
If the fan on the outdoor unit is running...does that mean the compressor is also running?
#13 |
An old Tradesmen
Air conditioner not starting - Help needed. |
#14 |
Probably won't find a replacement cap on a Sunday, huh?
| Display Modes | |
| Need advice on quantity of primer and paint needed | laurat | Painting | 8 | 01-01-2011 11:53 AM |
| Combustable air, how much is needed? | Lee Roy | HVAC | 9 | 10-27-2010 11:17 PM |
| no ductwork needed to install a wall fan ? | amakarevic | Plumbing | 2 | 01-22-2010 06:23 PM |
| Wire Needed for GF / Arc Fault breaker | jamiedolan | Electrical | 13 | 09-20-2009 09:15 AM |
| calculating amount of exhaust vents needed | bitty071203 | HVAC | 4 | 06-09-2009 08:13 PM |
