Old 11-06-2012, 11:29 AM   #1
Air Conditioner Loud Vibration issues
Recently I've been getting a low vibration/buzz noise from the handler unit that is located in a closet in my condo. When that sound happens I also get the same noise from my circuit breaker box. I am not sure if this is just vibration carrying through the walls or an actual electrical issue. If I press the box frame against the wall the sound in the box subsides, so I'm inclined to believe it's traveling vibrations.
This morning the unit was making a very loud vibration/buzz noise, which of course carried into the breaker box. The unit was not running and the sound seemed to emanate from where the copper tubing leaves the unit and runs into the attic to what I assume is the AC unit on the roof. Eventually the sound subsided.
I'm not sure how old the unit is as it has been there since I moved in 6 years ago.
skeev88 is offline   Reply With Quote
Old 11-06-2012, 06:05 PM   #2
An old Tradesmen
may have a shorting compressor or condenser fan motor.
Old 11-07-2012, 02:06 PM   #3
Thanks. I'm going to call someone out to look at it.
I guess a short in the unit would or could cause some kind of feedback in the breaker box, couldn't it.
Old 11-07-2012, 05:10 PM   #4
An old Tradesmen
Yes, it can make the wire sing sometimes too.
temperature and pressure issues jpa137 Plumbing 7 04-04-2012 10:48 PM
Pipe vibration from power vent water heater cerfsud Plumbing 4 01-10-2012 07:39 PM
House settling issues gmvshort Building & Construction 3 02-22-2011 07:26 AM
Demo'd Half-Bath, Issues, Pics Attached, Have at it... 99altrade Building & Construction 4 12-21-2010 05:50 PM
heater is very loud when on. SuperAkuma HVAC 6 12-16-2008 10:10 PM
