Air Conditioner Is Leaking - HVAC - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 11:09 PM   #1
Rewards Points: 22
Air conditioner is leaking
Air conditioner is leaking. We placed a tray underneath to catch all the water, and water even comes up from underneath the carpet. We've had this problem before and the repairman will blow out the drain line, it works for a while but it always stops back up and leaks again.
Any ideas what's wrong and what the long term solution would be.
Thanks.
JP79ST is offline   Reply With Quote
Old 07-18-2010, 12:23 AM   #2
An old Tradesmen
Rewards Points: 6,098
Blow out drain line. And then pour alittle simple green in the line once a month.
The Following User Says Thank You to beenthere For This Useful Post:
JP79ST (07-18-2010)
Old 07-18-2010, 08:05 AM   #3
Bleach works well also.
The Following User Says Thank You to Marty S. For This Useful Post:
JP79ST (07-18-2010)
Old 07-18-2010, 12:58 PM   #4
Rewards Points: 22
What about drain cleaner?
Old 07-18-2010, 01:09 PM   #5
An old Tradesmen
I try to stay away from both bleach, and drain cleaners.
Fumes from either aren't the best thing for the coil.
JP79ST (07-18-2010)
AC leaking condensation leaking into furnace jrf0022 HVAC 1 06-05-2010 08:52 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 05:43 PM
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 06:29 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
