Air Conditioner Leaked Freom - HVAC - DIY Chatroom Home Improvement Forum
Old 07-17-2013, 08:56 PM   #1
Rewards Points: 49
air conditioner leaked freom
a guy came over and said my freon leaked out thru the tubes going to the condensor. what pressures are these things pumped up too?
If i remove the tubes can i use an aircompressor to find the source of this leak.
I bought a new set of tubes just in case. this compressor uses the old refrigerent, does it pay to update the condensor?
How did he know the leak wasnt in the compressor?
who is lying to me?
john_bry is offline   Reply With Quote
Old 07-17-2013, 09:27 PM   #2
Rewards Points: 14,278
It's not a DIY job. Even cracking a line open is against the law unless your licensed to do so.
How old is this unit?
Did you watch him check for the leak? There's several ways to check for a leak but using compressed air is sure not one of them.
Old 07-18-2013, 12:45 PM   #3
Supplier
Compressor discharge can go well over 200 PSI in R22 units. You should ask the guy why he said the leak was thru the tubing or maybe he tested and saw the leak.
gsistore is offline   Reply With Quote
How I can repair My new air conditioner that drip water into my room? skolo HVAC 7 07-15-2011 11:12 AM
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 10:29 AM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 06:07 PM
Novel Way to increase effeciency of portable Air conditioner Tell me what you think macmini HVAC 5 05-25-2009 05:58 AM
Hole in Cinder Block Wall for Small Air Conditioner stevehgraham Building & Construction 1 02-20-2009 06:31 AM
