Air Conditioner - Just A Humming Sound - HVAC - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 11:29 AM   #1
Hello Everyone,
I got a call from my wife that the house was 87 F last night !
We have a split system Air Conditioner.
Seems the AC unit outside isn't turning on. All that comes from it is a small humming sound. Seems to be coming from the compressor. Is that what a compressor sounds like when it is running and the fan is not?
I thought maybe the starting cap went bad, so I tested it.
Compressor Cap - 35.8uF
Fan Cap - 3.25uF
Using the model info, I found a parts list. Says it has a 40+5MFD, I'm assuming that is just saying there are 2 caps in one package, a 40uF and 5uF. So is 36uF and 3.3uF close enough?
The contactor or relay is kicking on when I turn the unit on, and there is nothing else really in the system.
I can spin the fan with a screwdriver but it doesn't stay spinning.
Any ideas? Thanks in advance!
Blauvster is offline   Reply With Quote
Old 06-04-2010, 12:09 PM   #2
So wow! All my troubles were caused by a bug deciding to make a nice insulator in the contactor/relay.
I was checking voltages with the power on, and realized there was no continuity between the 240VAC in and the other side of the relay. All I initially checked was that the relay closed. Apparently a bug decided it would make a home between the contacts when it was off and when it came on realized it was a bad decision. Surprisingly to me is the resistance of a bug. It was measuring as an open circuit!
All the humming was coming from the relay.
Old 06-04-2010, 07:50 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,120
Yep. We even have a flat rate price in our manual for removing "earwig bugs". Birds going down chimneys are another favorite. Nature can be expensive.
Old 06-04-2010, 08:24 PM   #4
An old Tradesmen
Rewards Points: 6,112
Yep, make some money every year from ear wigs, and birds.
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 12:25 PM
humming sound from wiring in the ceiling to a light fixture njvcl Electrical 3 05-12-2009 11:00 AM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 06:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 08:36 AM
