Air Conditioner Installation, Wall-mounted Or Ground-sat? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 03:29 PM   #1
Air conditioner installation, wall-mounted or ground-sat?
I'm thinking purchasing an air conditioner. Now I have a question about the installation for the condenser. Someone was promoting that ground-sat, while others says wall-mounted is better. So please someone tell me which one is better or any advantages or restrictions for each.
Thanks!
lameon is offline   Reply With Quote
Old 04-30-2012, 03:45 PM   #2
Rewards Points: 616
we put all our on brackets and a condenser pad.... always stays level and keeps it up off the grass or whatever....
carmon is offline   Reply With Quote
Old 04-30-2012, 06:04 PM   #3
Rewards Points: 1,216
Usually the circumstances dictate what to use ground pad or up on a stand. Etherer way is fine.
COLDIRON is offline   Reply With Quote
Old 04-30-2012, 09:36 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
I've had units make noise through the foundation when put on brackets. Not always and not very often, but it has happened.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-30-2012, 09:43 PM   #5
Rewards Points: 616
I have heard the noise as well.... I have instlled hundreds on brackets and never a noise..... I agree it does happen.....
Old 05-01-2012, 08:57 AM   #6
Thank you very much to all the replies!
Coldiron, could you please give me some brief outline, in what circumstances that ground pad is better and in what is good to go with brackets? Thanks.
Tags
installation condenser
Can Ground Water Wick Up A Foundation Wall? 99bobster99 Building & Construction 63 06-30-2012 07:21 AM
Wall cabinet mounted next to pantry cabinet ryan.kelly Carpentry 2 10-13-2011 08:50 AM
question on 240 wire size and ground for wall oven twobyfour2 Electrical 8 04-30-2011 08:13 AM
wall mounted residential toilet kr bennett Plumbing 10 12-05-2010 11:03 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
