Air Conditioner Fins - HVAC - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 10:13 AM   #1
Air conditioner fins
i understand about them (fins) being bent but what if the are corroated and like dust at the base of the unit. is this a breathing hazzard the unit cools really well.
Homedooer is offline   Reply With Quote
Old 09-10-2012, 10:24 AM   #2
Rewards Points: 13,270
The outside unit has nothing to do with the air blowing inside the house.
The unit outside really needs to be kept clean and the fins straightened out for proper operation.
http://www.bing.com/shopping/search?...comb&FORM=HURE
These are what's used to fix the fins.
Homedooer (09-10-2012)
Old 09-10-2012, 12:58 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
A condenser, the outside unit in question, rejects the heat absorbed by the inside evaporator coil while the refrigerant changes from a high temperature vapor to a liquid. It can not reject all the heat without the proper air flow and with enough of a blockage stands a chance of the refrigerant not condensing fully into a liquid. Vapor back to the evap equals no cool.
Keep those coils clean results in lower supply air temp and improved efficiency, lower electric bill, etc.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-10-2012, 03:45 PM   #4
The only time I've seen the fins actually corroded away was where the dogs were relieving themselves on it. Could this be an issue for you?
Evstarr is offline   Reply With Quote
Old 09-10-2012, 05:48 PM   #5
biggles's Avatar
inside air handler no big deal condensation and dust..if outside on the condenser also common especially with pets around...
How I can repair My new air conditioner that drip water into my room? skolo HVAC 7 07-15-2011 12:12 PM
Air conditioner Condensing coil fins Tony vargas Electrical 2 05-04-2011 01:51 PM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 07:07 PM
Stucco Fins vs. Nail Fins on Stucco House xquercus General DIY Discussions 5 01-25-2009 05:44 PM
