Air Conditioner Evaporator Coil Keeps Icing Up - HVAC - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 11:46 PM   #1
Air conditioner evaporator coil keeps icing up
My air conditioner evaporator coil keeps icing up. Itís in an air-handler inside my house and it is an A-frame coil. I cleaned the filters and the coils donít seem to be dirty as far as I can tell airflow is fine. When it is iced up the ice covers the entire coils top to bottom on both sides. But when the ice is off and the unit is running the frost line is only half way up the coils on both sides. The top of the coils doesnít seem to be refrigerating at all (not wet or cool). This would indicate to me that its low on gas but why is it that when it is iced up the entire coils is iced. I am an appliance repairman and I have the equipment to make all necessary repairs.
I havenít put gauges on it to see the pressure yet just wanted to see if anyone had any thoughts on this and any help would appreciated.
applianceman is offline   Reply With Quote
Old 05-26-2009, 05:39 AM   #2
An old Tradesmen
Rewards Points: 6,452
Because it takes X amount of time for it to freeze/ice up the lower portion where you see the frost.
Once that portion becomes ice.
The liquid refrigerant can travel further up the coil and freeze it also.
Find and fix the leak.
Old 05-26-2009, 08:50 PM   #3
Thanks for the reply. I ended up putting a pound of gas in and now its working fine. Now I got to find and fix the leak.
Novel Way to increase effeciency of portable Air conditioner Tell me what you think macmini HVAC 5 05-25-2009 06:58 AM
Hole in Cinder Block Wall for Small Air Conditioner stevehgraham Building & Construction 1 02-20-2009 07:31 AM
Installing window air conditioner mary60 Electrical 1 08-14-2008 07:25 PM
window unit air conditioner help? greenvorlon Appliances 1 08-03-2007 12:50 PM
Air Conditioner HELP jray2855 HVAC 6 06-30-2006 09:41 AM
