Air conditioner condenser placement question
What's going to have to happen is a platform will be needed to be built and anchored to the wall so the condenser can sit on the platform. I'd set the condenser on rubber vibration isolation pads as well as use a minimum of 1' thick insulation on the low pressure line, make certain the high pressure line is taped tightly to the low, use foam sealant in all crevices/wall penetrations and lastly buy and install a compressor sound blanket.
Even then you will hear something.
Thanks.
