Air Conditioner Condensation - HVAC - DIY Chatroom Home Improvement Forum
Old 09-25-2011, 12:53 PM   #1
The plastic condensation drain pipe is working properly (as in draining outside) but in the attic (where the furnace is), the pipe (about two feet long) coming out of the condensor housing and running to the main drain has condensation building on/dripping off the bottom of it which drips on to the floor. I put a pan under the pipe to catch the condensation and it does seem to evaporate, but should I do more?
Hope I made this clear enough.
john curry is offline   Reply With Quote
Old 09-25-2011, 03:20 PM   #2
Tug
IMO you have a short term fix for a long term problem. I'd probably wouldn't risk it fix the problem before it becomes worst and creates more problems down the road
Tug is offline   Reply With Quote
Old 09-25-2011, 03:23 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
You dont't have a condenser in your attic, you have a furnace and an evaporator. The main drain comes out of the evaporator and should be insulated the first ten feet at least for exactly this reason.
Doc Holliday is offline   Reply With Quote
Old 09-26-2011, 09:07 PM   #4
I agree with Doc, the condensate water is very cold. Insulating the pipe should solve your issue.
Chaingang is offline   Reply With Quote
How I can repair My new air conditioner that drip water into my room? skolo HVAC 7 07-15-2011 11:12 AM
Really Condensation? Or is it a Leak? DTproject Plumbing 6 02-21-2011 07:01 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Air Conditioner Condensation Issue Unregistered HVAC 1 07-23-2004 02:10 PM
