Air Conditioner Blowing Cool But Not Cooling House - HVAC - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 08:03 PM   #1
Air conditioner blowing cool but not cooling house
Hi,
I'm having a problem with my air conditioner. It's blowing cool air, but it's not cooling down the house. This morning i noticed that the outside of the unit (the unit i have is a round one) was full of dog hair, so I vacuumed that with the brush attachment so i wouldn't bend any of the metal pieces.
That didn't work, so I researched online a little, and saw stuff about the circuit breaker. I turned the one from the basement off then on again, but i didn't do anything with the breaker that's next to the unit outside because it's screwed in, and I don't want to mess it up.
While i was outside looking at the breaker outside, I did notice that the pipe thing coming out of the unit going to the house was covered in frost. And there is condensation on the furnace downstairs. I'm not sure if any of that matters, but I thought i would mention it.
I don't want to call a HVAC guy today because 2morrow is the 4th of july and i know that i will cost a fortune, so any help would be greatly appreciated.
THANK YOU!!!
roguefox64 is offline   Reply With Quote
Old 07-03-2011, 10:56 PM   #2
30 year tech
hvac122's Avatar
Your coil at the furnace is frozen up. Have you changed the filter lately? Turn the fan to on and that a/c to off to defrost the coil. You either have low air flow or are low on refrigerant. Defrost for at least a few hours before trying it again.
hvac122 is offline   Reply With Quote
Old 07-03-2011, 11:13 PM   #3
Thank you for the response. I'll have a friend come over to check to see if the filter needs changing in the morning (i'm not sure how, to look at it) When you say turn on the fan, do u mean the fan that's on my thermostat or just a floor fan. I turned off the A/C and will leave it off until i either get the filter changed, or have someone look at it. THANK YOU!!!
Old 07-03-2011, 11:21 PM   #4
30 year tech
hvac122's Avatar
Turn the fan to on at the thermostat. Have them show you how to change the filter. It should be done monthly. Good luck.
Tags
air conditioner , havc
New AC not cooling house emmismee HVAC 5 06-01-2011 12:28 PM
dayton furnace blowing cool air luckysc47 HVAC 2 12-05-2009 12:04 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
Effeciently cooling a 2 story house??? jsalassi HVAC 4 06-10-2006 11:35 AM
